Rear tire leaking rimguard
   / Rear tire leaking rimguard #1
p0peye
Bronze Member
southern tier Ny
JD 2520
I have a leak coming from the inside bead around the rim. The rears are loaded with Rim guard and leaking . Is there a easy fix or do I have to take the tire to the dealer. I have r4s on my JD2520 .
   / Rear tire leaking rimguard #2
I'd say no easy DIY fix.
Rimguard will need to be pumped out, rims wire brushed and a rim sealant applied, tires reseated and rimguard re-installed.
If you have a major truck tire dealer nearby they might be the most cost effective source for that sort of work as they would have necessary equipment for that task.
   / Rear tire leaking rimguard #3
PILOON may be correct... but, before I'd resign myself to draining the tire, etc, etc.
I'd locate the leaking area - jack the tractor up and rotate the wheel so that the leaking area is above the fluid level - and then pump the tire up with air to 30-40psi. Let the tire sit overnight (or a couple of days). The next day or so, drop the air pressure down to the highest psi recommended for the tire - probably around 16psi - I'd guess; and see if it's still leaking.
The additional air pressure may reseat the tire bead and solve your "drippy" tire problem without having to completely dismantle it!
AKfish
   / Rear tire leaking rimguard #4
I suspect you may not have had enough air on top of the RimGuard, which permitted a foreign object to wedge between the bead and the rim. Assuming over-pressure doesn't work, the fix may not be complicated. But is likely to be difficult because of the weight involved.
I couldn't do it myself, my R4 rears probably weigh over 500# each. And I don't know if it could even be done safely with two people. But - with enough people and/or the right kind of equipment - the tire could laid flat with the leaking side facing up. If this puts the valve stem pointing at the ground, any remaining pressure should be released first. Once deflated and lying flat, the leaky rim seal should be broken. The remaining RimGuard will occupy the bottom 70% of the tire. The upper 30% will be an air pocket. This will permit you to reach in and clean the bead and the rim. Add air to reseat the bead, stand tire up, check for further leaking, reinstall if successful.
//greg//
   / Rear tire leaking rimguard #5
It seems you would be best off getting it fixed at a shop. The expense in your case will be the pumping the fluid out and then back into the tire. I suggest you have them install an inner tube and that would curb future trouble like this. My neighbor uses his tractor a lot and and gets flat tires all the time. He had the tubes installed and that saves some trouble if not all.
The tire was very low on air pressure also so we put in 30lbs and will try it today to see if this helps. But if there is a leak around the bead why doesn't the air pressure force out the rim guard . Thanks for the replies.
   / Rear tire leaking rimguard #7
most likely you have dirt or something inside of your bead. I digress with others how to handle it and get it pumped out and back in.
If it only leaking one side of tire, and if you can get a helper to take tire off and roll it to your FEL. I would set tire down with good bead side down and leaking side up. (make sure you are close to the air compressor and have tractor blocked up safely) Use the FEL to pop the bead and then clean it good and wipe everything down with towel. re air it back up. Since you shouldnt be loading tires with liquid more then 75 percent, putting tire down on one side will hold the liquid in with good bead still holding.
   / Rear tire leaking rimguard #8
Because the Rim Guard is not pressured sufficiently enough with the rather small area of air which is pressured. If it were high pressured, it would turn with the wheel. Personally, I think it is always a good idea to use a tube for liquid in rears. I've had calcium in my rears for 25 yrs with nary a mishap using tubes.
   / Rear tire leaking rimguard #9
Assuming you don't have some foreign object/material between the tire and the rim...
During the course of the winter and not using or moving your tractor (or a vehicle) very often; the contraction and expansion of tire/rim/rim guard with fluctuating temperatures, the bead may develop a slow leak. That's a common occurrance. Happens all the time with any kind of tired vehicle or implement.
My JD 110TLB had that happen just this past month or so. Tire leaking and going down... pump it up... goes back down... pump up... back down.
Finally just elevated the tire and overpressurized it for a couple of days.
Hasn't leaked down at all for weeks now.
AKfish
Depends upon where the fluid level is and the seal break on tire bead and the rim is located. Once all the air is displaced and just fluid remains inside the tire if the bead seal is leaking at the ground level, you'd expect that a sheen of fluid would eventually appear. Nothing major... just a light moisture.
   / Rear tire leaking rimguard #10
That doesn't make any sense -- what are you trying to say?
2025 K0608 UNUSED 3-Rail Style Fence Panels (A50860)
2025 K0608 UNUSED...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2021 Chevrolet Tahoe FL SUV (A48082)
2021 Chevrolet...
T3 Motion Patroller Segway (A48082)
T3 Motion...
2007 IC Corporation PB105 Passenger Bus (A48081)
2007 IC...
