Rear tire chains for S470D Buck
   / Rear tire chains for S470D Buck #1
Botetourt
Bronze Member
Virginia
Mitsubishi 470D
Well, I guess it's time to get chains for the Buck. I've got the "diamond pillow" turf tires and I need to be able to scrape a 450' gravel driveway, which is on a hill, when it snows. I've got plenty of traction for rear blade work with the gravel, but frozen stuff may be a different story. Looked around a little and looks like nobody has the 9.5-18 size. I'm going to email TireChains.com, who says they'll make them up.
Anybody know a good source?
What style chain works well on this tractor?
Any clearance issues with the fenders? Looks a little tight there.
Any other chain tips? I've never used them at all on any vehicle.
   / Rear tire chains for S470D Buck #2
I've only used chains a little bit, basically while I was in college in Pacific northwest. The only useful contribution I have for you is to put them on now, rather than when you need them, and to put them on someplace warm, rather than out in the blowing snow...
I found it easier to put the inside on tighter, then after driving a bit, pull the remaining slack out where it is easy to reach, on the outside of the tire.
I would check the clearances before you order anything, just to make sure you can fit them in there.
I got a quote for 3/8", 4 link ladder style chains from TireChain.com. Price is $139.75 plus $34.99 shipping. Needs 1 1/2" fender clearance. What they have are too long and require cutting down, but that may be common. Maybe a more robust design, even 2 link, would be better, but these will probably work. Also had 5/16" chain for $120.76 plus $21.99 shipping. Seems like the larger chain is worth the difference.
2015 Ford F550 Altec Bucket Truck (A52377)
2015 Ford F550...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
(APPROX 25) UNUSED LANDHONOR PINS (A54757)
(APPROX 25) UNUSED...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A54757)
UNUSED WOLVERINE...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
