Rear Tire Ballast
/ Rear Tire Ballast #1
Oiltech
La
Kubota L3540HSTC, M7060HDC-12, ZD331-72, Bobcat E42
What is the preferred media to add to the rear tires?
/ Rear Tire Ballast #2
If you are in area where it never freezes water will work. The preferred fluid in colder climates in Rim Guard which also weighs more than water.
Some people also use RV Antifreeze or windshield washer fluid.
/ Rear Tire Ballast #3
Rim Guard is best, but nobody around here has it, so I got some kind of alcohol/water mix. Works fine.
/ Rear Tire Ballast #4
Boy this is a loaded question...... Are you concerned about cost per pound of weight gained???? Or are you concerned with the most weight gained with a certain amount of fluid. Or are you concerned about corrosion?? Or are you concerned about environmental friendly fluid??
See how confusing this gets.
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
WOODS TBW144 TURF BATWING ROTARY MOWER (A62130)
WOODS TBW144 TURF...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A61568)
2015 Hyundai...
2006 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2006 JLG 600S...
300 GALLON PORTABLE POLY TANK (A62130)
300 GALLON...
