rear remotes
   / rear remotes #1
seedman4
i just bought a new mihindra 3525 with a front end loader.i need rear remotes.i know the dealer sells a kit for the rear remote for 600.00 or so.
My question is can i use the hydraulics that run the front end loader for the rear remote system if i buy extra hoes and fittings???
   / rear remotes #2
I just replied to your other thread, Please do not double post:D
   / rear remotes #3
seedman4 said:
i just bought a new mihindra 3525 with a front end loader.i need rear remotes.i know the dealer sells a kit for the rear remote for 600.00 or so. My question is can i use the hydraulics that run the front end loader for the rear remote system if i buy extra hoes and fittings???
Well, assuming it is kinda like my 4110, in a sense, you will be using hydraulic flow coming from the front end loader's control valve... through the power beyond connection that now goes to the main control valve (i.e., 3-pt control)... but you still need a way to control and utilize that flow. I suppose you could disconnect the FEL bucket curl function quick disconnects and run temporary hoses from there to the back of your tractor... but as crazy expensive as it sounds right now, believe me: the rear remote kit is definitely your best bet. And if a double kit is available, swallow even harder and go for it. It will hurt once very badly, but I swear that after the initial pain passes, you will never regret it. :)
Dougster
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
City of Lakeland (A51691)
City of Lakeland...
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
