Rear Remotes on BX2230
   / Rear Remotes on BX2230 #1
Eightpoint
Virginia
Kubota BX2230
I am contemplating adding rear remotes to my BX2230 to "trick it out" a little bit. I would like a TNT arrangemnt to make my life easier with hooking up and adjusting implements such as my box blade. Am also considering a bolt on grapple sometime soon and thought that this may be a way to power them (by running hoses from the rear to the FEL).
I ran across a rear remotes setup on ebay for a BX24 or BX25 and am wondering what it would take get the necessary plumbing to the back of my machine in order to use this setup. I know that posting links to ebay auctions is a no no on here but the item number is 170298681796 if you want to look it up. Any thoughts on the effort involved in getting the plumbing setup to the rear of my BX2230 to make this work or would I be better off going down another path?
Thanks - Eightpoint
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
(INOP) KOMATSU PC200LC-8 EXCAVATOR (A51246)
(INOP) KOMATSU...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
TOSHIBA 8000 BTU WINDOW AC UNIT (A51248)
TOSHIBA 8000 BTU...
