Rear remotes now, bh6000 IN FUTURE ???
   / Rear remotes now, bh6000 IN FUTURE ??? #1
James.Hering
Clarksburg, MD
kubota 2230
Hello all, I am a new member here. I love this forum. I am an owner of a BX2230. I would like to get a hydraulic toplink now, but am considering a BH6000 in the future.
My question is, What remotes should I buy now for the toplink, so that I don't waste money in the future if I get a Woods Backhoe. I assume the BH kit comes with remotes and hydraulics. Would these be in addition too the toplink remote or would I use the BH remotes for the toplink.
I have been lurking for months, reading every thread I can on BH6000 and toplinks. I am still trying to figure out what I need to do.
Thanks for any advice.
Jim
   / Rear remotes now, bh6000 IN FUTURE ??? #2
Welcome to TBN.
I do not claim to be an expert in this department as I have no hyd top link or back hoe or remotes for that matter, but i have worked with hyd and understand the principles. (How is that for a disclaimer upfront using our common conjunctions?!!)
The remotes for a top-link and a bh are fundamentally different. For the tl you have a valve that controls a cylinder, whereas for a bh you are drawing on the hyd pump from the tractor directly through a power beyond port in the loader circuit, without any intervening valve to direct flow to the bh.
Flow with the toplink Pump - FEL valve - (PB) - top link control valve - 3pt - return. In this situation the remotes are connected to and controlled by the tl control valve.
Flow with backhoe Pump- FEL valve - (PB) - remotes (which must be connected through the bh valve or by a hose) - 3pt - return
I know that this is drastically simplified and assumes the FEL which is not a requirement, but it shows the fundamental difference between remote connections for a bh and top link.
The bottom line then is that the remotes are radically different and therefore would not be duplicated in a top link install.
I hope that is clear--if not I will try to clarify or allow someone who has experience in this more specifically explain.
Mike in Warsaw
   / Rear remotes now, bh6000 IN FUTURE ??? #3
That is the question, isn't it. The Bx2230 was never designed to accept a Backhoe, however with the Woods kit, it works. Your dealer may know if the rear hydraulics kit is compatable with the BH. Considering the rear hydraulics kit costs less than $300 if you install it yourself, and the BH is around $6000
I wouldn't feel bad starting with the kit first. Even if it doesn't work with the Woods BH, you delayed that big investment awhile.
Best of Luck
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
JOHN DEERE 3033R LOT NUMBER 225 (A53084)
JOHN DEERE 3033R...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
