Rear remotes for a 4720?
   / Rear remotes for a 4720? #1
BobQ
Conn
Can any one tell me what it would cost for rear remotes? and maybe a photo of what the install looks like?
Thanks Bob
   / Rear remotes for a 4720? #2
Thanks Bob
My dealer said about $500 for a single, $1,000 for dual.
I think there were pictures in the brochures I gathered before buying the tractor... probably gone to trash a while ago.
   / Rear remotes for a 4720? #3
I put hoses and quick D connections on my 3510 to run a Jinma Hoe. I also put a relief valve in the circuit for security. As I recall it cost me under $100. I don't have a valve in the circuit.
Under the right fender, above the axle there is a figure 8 dog bone fitting on the rearend housing, I think this is called power beyond. One is pressure the other is return. I bought metric fittings to JIC to fit these openings. I bought short hoses with 90* JIC on one end and Pipe on the other. I put the relief valve between the hoses. Looked like an "H" and short hoses to the quick disconnects.
   / Rear remotes for a 4720? #4
That damned 8 dog bone is in fact two 20mm x 1.5 banjo fittings and a short length of steel pipe between them. If anything it is more likely "Power Before" than "Power Beyond" (-:
The thing that irks ME is that I can't find anyone who will make up hoses with banjo ends.
Heck, I already HAVE the bolts, I just want banjo ends on hoses so I can run them back at whatever angle is right without having to mess with adapters that will stick out and then 90* adapters to aim the hose to the back of the tractor.
Anyone try salvaging the banjo fittings from the dog bone ?
I have to believe there is enough flow through that sized banjo, I think all the flow goes through there anyway.
INGERSOLL RAND INDUSTRIAL AIR COMPRESSOR (A51248)
INGERSOLL RAND...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2004 Mack CV713 Granite Fuel and Lube Truck (A51692)
2004 Mack CV713...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
2016 Chevrolet Colorado Pickup Truck (A51692)
2016 Chevrolet...
