BlacknTan
Platinum Member
I've got everything to install my rear remotes. The only thing I have a question on is plumbing.
First, I've got a Kubota B-7800 with FEL.
I've read here many times that the hose from the loader valve PB port to the hydraulic block should be removed. A hose then goes from the PB port on the loader valve to the input on the remote valve. a hose then goes from the PB port on the remote valve back to the hydraulic block where the hose previously removed went. Then, a hose goes from the output port of the rear remote valve back to the tank..
In picking the mechanic's brain at my kubota dealer, he said that is unnecessary. He said he merely removes the hose from the loader valve PB to hydraulic block, and then runs a hose from the PB on the loader valve to inlet of the remote valve, and runs another hose from the outlet of the remote valve back to the hydraulic block (return).. A simple loop. He said that he has been installing rear remotes this way for 27 years.
A hydraulic expert at Cross MFG, the remote valve manufacturer confirmed the mechanics thoughts.
Why are all the remotes at TBN plumbed with the three hoses as in the first method as opposed to the mechanic's second method??
Are there advantages of one methos over the other??
What am I missing??
What am I missing??
