Rear remote lever won't engage
   / Rear remote lever won't engage #1
bmillerag
Flat Rock, Indiana
bobcat ct230
Have a ct230 with a rear remote working a grapple. Has worked fine for two years and all of a sudden today it started to stick in the forward position. Was able to get the lever pulled back in neutral and now it won't work the grapple. The lever moves but nothing works. Also sticks really bad when you have it push forward. Any help would be greatly appreciated.
Brad
   / Rear remote lever won't engage #2
No help I suppose but when my lever is pushed in the lock position forward or backwards it takes a pretty good push to move it back. All other hydraulics working as they should?
   / Rear remote lever won't engage #3
I had my remote lever without detent lockup once when a coupler was not fully locked in place. That could also explain no function now if coupler has backed off enough to close the poppet.
I unhooked my grapple lines and hooked them back up and still sticks. I do have function . I bent back the rod and I have full function now. Just sticks bad when pushed into the lock position
   / Rear remote lever won't engage #5
The manual shows detent balls inside that hold the spool in the detent position but nothing as far as trouble shooting. No adjustment to them that I can see.
   / Rear remote lever won't engage #6
If you are using the remote lever closest to the seat it may have the detent which are prone to getting dry or rusty and stick. The detent is removable without disassembling the valve it is located adjacent to the control lever. I only needed detent for occasional use of wood splliter so I removed the spring and balls form it an put the cap back in then use a bunging cord to hold the handle when splitting wood. Sorry, I did not take photos of removing it, but there was a thread some time ago in Kioti forum showing this.
If you have 2 remotes run it from the other one. I run grapple with the outer lever remote as it is easy to get my hand on, not as close to the seat.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2015 BMW (A50324)
2015 BMW (A50324)
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
2022 Ford F-550 XL Crew Cab Forestry Chipper Truck (A49461)
2022 Ford F-550 XL...
