Rear pto vs front Pto Hp
   / Rear pto vs front Pto Hp #1
Rambo33
Australia
Massey Ferguson
Gday everyone.
Hypothetical, if you have a 100hp tractor with 85 rear pto hp, does that translate to also having 85hp at the front pto or is there a loss/less power at the front pto.
One dealership told a mate its lower at the front, another dealer told me with their tractors there isn't a loss at the front
Thanks.
   / Rear pto vs front Pto Hp #2
I don't know, but being there is less friction loss in the front, it should be a little higher.
   / Rear pto vs front Pto Hp #3
Hypothetically speaking the answer is Yes
   / Rear pto vs front Pto Hp #4
To lose horsepower between the engine and either PTO requires converting mechanical energy to some other kind, which of course would be heat in this case. It's hard for me to imagine there are things generating thousands of watts more heat along one drive chain than along the other. For one thing there'd have to be something in the transmissions reaching a very high temperature or else moving a whole lot of air to carry the heat away at a lower temperature.
So it could be brand specific if there are losses, depending on how the tractor is designed. The deutz dealer, who i know is a mechanic by trade was confident theirs didn't have a loss, or much of a loss due to the design.
   / Rear pto vs front Pto Hp #6
Found this today looking for front 3pt for an Unimog:
DID YOU KNOW? Zuidberg Front PTOs offer FULL ENGINE HP out the front shaft? This is CRITICAL, especially under heavy loads like snow blowing, running larger mowers or chopping large branches in the orchard.
So one of the tractors in question is a New holland t4.110f. In the specs the rear pto is making 107hp at 2300rpm. The dealer just got some info to us, the front mount pto from factory is capable of 93hp at 1920 rpm.
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A43003)
2015 FREIGHTLINER...
2011 FREIGHTLINER CASCADIA (A45046)
2011 FREIGHTLINER...
2017 CAT 420F2 IT BACKHOE LOADER (A45046)
2017 CAT 420F2 IT...
264 Gallon IBC Tank With Drain Valve (A42745)
264 Gallon IBC...
Bumper Assembly (A42745)
Bumper Assembly...
PALLET OF PIPE CUTTING AND WELDING SUPPLIES (A45333)
PALLET OF PIPE...
