Rear Finish Mower Rear PTO Leaking HD Fluid When Finish Mower Is Connected
   / Rear PTO Leaking HD Fluid When Finish Mower Is Connected #1
ampa
The Finish Mower Driveshaft tends to push the PTO shaft in about an inch...I own a low hr Compact ISEKI Tractor....if I can keep the PTO connecting shaft out past the oil seal everything is okay and it don't leak..am I missing some kind of a spacer that should be used with this used Finish Mower or is it time to remove the PTO back plate and install shims/oil seal....I'm lookin' for advice as I never had to use the rear PTO up till now...Thanks in advance....AMPA
   / Rear PTO Leaking HD Fluid When Finish Mower Is Connected #2
If I understand your description correctly, it sounds as though your pto shaft on the mower is too long. You should have to telescope the shaft out in order to hook it up to your tractor and it should NEVER EVER be putting forward pressure on the tractor's pto shaft. You should be able to run the 3 pt lift up and down the full range of motion and the shaft never completely collapse against itself. If it is putting pressure forward against the tractor's shaft then you will need to shorten the telescoping portion by maybe 2 inches on each half of the telescoping shafts. That's the extent of my knowledge :p
Troy
   / Rear PTO Leaking HD Fluid When Finish Mower Is Connected #3
Troy
I Agree with Troy . Hopefully it Hasn,t caused any Damage, :eek: But sounds Like the PTO Driveshaft for the Mower is to Long .
Neither Of My Isekis am I Able to Push the PTO Shaft on the tractor in So I,m not sure whats Taking place Al . I Still Haven,t Got around to Getting My Manuals Yet So I,m not Sure Whats involved inside the PTO on the Tractor. I Also Hope I dont need to Find out. :D . Best of Luck Getting it Sorted out . Bob
I bought this FM cheap and missing lots of parts...the dealer found the PTO shaft but the outer part was twisted like a cork screw...so I had no choice but to cut it almost in half to get it to fit over the inner shaft...I didn't want to cut the inner at all since there was only about less than half the lenght of the outer to connect I can slide the shaft back towards the gear drive with no problem....I'm going back up to the dealer to tell him and show him the twisted piece I had to cut off....he gave me the operating/service and parts manual and it mentions to make sure the spacers are used...I have no clue as to what these look like...maybe these spacers keep the PTO shaft from sliding inward....thanks Toy and you too Bob... by the way I sent you an email Bob so let me know if you recieve it...I had to use explorer for my email server...so I now have a new email ad I sent with the sent email....I'm taken my lady out in a few minutes to get some more needed groceries... so I'll catch up with you when I return.......AMPA
Hi Bob......I reversed the large 3 point hitch pins (2),as I noticed on your old Finish mower, this Finish Mower I bought must have been on a much larger tractor, as I woud have had to add another link to each of the sway chains, so by reversing the pins they fit the way I had them for my Grader/Snow plough, so just maybe the PTO will be fine and not lealoil, if not I'll just replace the PTO oil seal, should be able to get an oil seal from the Kubota dealer where I bought the used finish mower, by the looks of the rear axel on the Kubota they seem to be the same, I think a lot of parts from Kubota will fit this ISEKI of mine, unless you know where I could order the proper PTO oil seal,I'malso thinking there may be shims to add so the PTO shaft does not move in about an inch, as for the gasket I can probley make one or use instant gasket goo,seems there is a cast iron plate to remove and the seal just presses in, I have the repair manual i'll have to study it, maybe someone on here has replaced one before and can give me some info on how hard or easy it is to replace and if there are shimwashers to keep the PTO shaft from sliding in a inch past the oil seal causing it to leak badly, like it pours through the space beyound the shaft near the splines, anyhow I hope I can fix this problem myself without to much trouble, like I hope there are no clips or springs flyin'out allover the ground as I have to do this outside, Thanks in advance....AMPA
   / Rear PTO Leaking HD Fluid When Finish Mower Is Connected #6
Good Morning Ampa , I Received a PM here, But No Email to The Email Addy I Gave You , Not sure if Thats What You Mean or not , Personally I Cant Stand Outlook Express , I Never can Get Them to Send, So I Opened a Free gmail acount , Much less of a pain. & Thanks for the Info on The Sandblaster , I,ve Got A More Then Big Enough Compresor to Supply Plenty of air to it, So I,ll start Looking for a Cabinet :D .
I Dont Know What to Say About the PTO deal going in to far , I Tried to Look at Mine & see If There was some Kind of an Outer Snap ring of Sometime , But There to darn dirty ta see. :eek: . Mother Nature Might give a Wash job this morning though :D , So i,ll look again Later. Seems Like the Only Thing that Makes Sense to Me. Might look in Your Book & see if It Shows Something like that, It Might just be Missing if so. Not sure though .
Glad to Here Your Getting Your Mower Deck Figured out though . & Heres a List of the Parts Suppliers in the US Larso1 Kindy posted in the Iseki forum .Hope that Helps , I,ll Let You Know if I can see anything on My PTO shaft Later. Take Care , Bob
You might want to start with Len at Sheaffer's Town & Country Tractors Inc.:
ISEKI suppliers in the USA
Sutton Tractor
6709 North I-35
Edmond, Oklahoma 73034
(405) 340-0268
Grey Market Tractor Parts
1-800-700-4739
Email: "mailto:suttontractor2@hotmail.com"
Rainbow Distributors Inc. (only distributor of new Iseki Equip. in USA))
Website: "http://rainbowdistributors.com/Tractors/tractors.html"
Homestead Tractor
22311 Bear Valley Road
Apple Valley, California 92308
Telephone: 760-240-1062
Fax: 760-240-1126
Email: "mailto:hstractor@earthlink.net"
320 Palmyra Road
Dixon, Illinois 61021
Phone: 815-284-3226
Fax: 815-284-5050
sheaftractor@grics.net
Southern Global Tractor
230 North Magnolia drive
Wiggins, MS 39577
Toll-free: 866-742-5748
Telephone: 601-928-7491
Fax: 601-528-9312
Email: "mailto:acker@ebicom.net"
Sonny's Farm & Home Supply
1733 N 200 W
Portland, Indiana 47371
Phone (260) 726-2808
Website: "http://sonnys_bolens.tripod.com/index.htm"
EFC Equipment LLC
Although we are not a parts distributor we are a full service Iseki repair shop. Bring your toy umm....tractor in or we can come get it. We have a 24hr service truck that can even repair your Iseki on site. No job to small or too big. We also carry loaders for every model Iseki and filters:
1243 Montana
Richland, Wa 99301
509-374-3398 shop
509-521-1507 24hr service
"http://www.efcconstruction.com"
Valley Power Products, Inc.
3646-5 Aerial Way Drive,
Roanoke, Va. 24018
I can supply new and used parts for the Mitsubishi engines used on some of the models. I also sell manuals for the Bolens versions, from 15 to 27 hp. Call 800-609-5110, "mailto:vppinc@rev.net" or
We sell parts and manuals for Satoh/Mitsubishi tractors. 540-345-9650
Monarch Products
Glow plugs and spark plugs, with cross references by manufacturer, engine number, and tractor model.
1-888-800-9629
"http://www.sparkplugs.com"
DESSCO (Isuzu engines and parts, glowplugs)
801-972-1836
Welcome to Diesel Electric Service & Supply!
   / Rear PTO Leaking HD Fluid When Finish Mower Is Connected #7
I expect your low hour Iseki has many more hours than you think. It is very easy to unhook the hour meter. I have a TU 1700 and have replaced the PTO seal more than once. The snap ring on the end of the PTO shaft comes off. I don't know the reason, other that the shaft being worn on the snap ring end. Easy to replace seal, just don't know when it's going to happen again. Must drail all the oil to replace snap ring. If anyone has any ideas I will be glad to listen.
Eddie
   / Rear PTO Leaking HD Fluid When Finish Mower Is Connected #8
bearing carrier groove may be bad also, letting hte snap ring pop out.. happens on fords sometimes.. usualy cause is drivelines that are too long that force the pto stub into the tractor.. popping snap rings and such!
soundguy
2008 VOLVO VHD64B CRANE TRUCK (A52141)
2008 VOLVO VHD64B...
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
Woods Brush Bull 7' 3 pt Mower (A50514)
Woods Brush Bull...
Detach Trailer (A50514)
Detach Trailer...
8'x8' Aluminum Cover (LOCAL TOWNSHIP) (A50774)
8'x8' Aluminum...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
