Rear PTO does not engage (NH TC19)
   / Rear PTO does not engage (NH TC19) #1
chanwmr
Maine, NY
NH TC25D
I got a bit overly aggressive trying to move some heavy (and high) snow with the rear mounted blower. The rear PTO suddenly stopped. The shear pins didn't give (probably due to the snow already clogging up the auger). There was no unusual sound or anything indicating anything major snapped at the time. After clearing out the auger, I was able to freespin the drive shaft and the auger by hand. But, it would no longer work by engaging it via the lever. I called up the local dealer and they think either the clutch is shot or some gear inside the drive box broke. He quoted me with something rough to get it fixed at the shop: something like between $1000 to $1500 or more. My question is whether I should attempt to fix something like this myself. I am handy with small tasks and understanding most concepts when it come to anything mechanical but I have never done anything hardcore with a tractor. Plus I may not have the tools to perform the job. Any tip or suggestion on either the damage or the repair would be appreciated.
   / Rear PTO does not engage (NH TC19) #2
I have never looked through a NH service manual but if they are written as clearly and thoroughly as John Deere service manuals you will have no problem taking your tractor apart, doing the repairs and putting it back together.
You haven't mentioned any unusual noises at all so I'm wondering if it isn't something electrical. If the clutch went you should have noticed it slipping. If something broke inside then you should have been able to hear that too.
   / Rear PTO does not engage (NH TC19) #3
Before you tear anything apart...look under the tractor and make sure the linkage is functioning properly.
I wouldn't tear into the tractor without a service manual.
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
SKYJACK SJIII 3226 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3226...
2019 CATERPILLAR 303E CR EXCAVATOR (A51246)
2019 CATERPILLAR...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
2007 VOLVO VHD64 TRI AXLE DUMP TRUCK (A53426)
2007 VOLVO VHD64...
