Rear lines
   / Rear lines #1
biggdadd58
Wellsburg
Mahindra 3016
Would any of you out there know about how to get some lines back to a hoe on a Mahindra 3016 tractor? I have a hoe from a previous tractor that I want to use but the dealership says that they have never hooked any up. All of their tractors come in plumbed. I can not believe that problem solving has become extinct! I am not sure, but I would hope that there is someone out there that can help.
   / Rear lines #2
If your "dealer" doesn't know how to plumb a set of rear remotes or power beyond, you need a new dealer now. How can they possibly service your tractor if they cannot do such a simple task?
   / Rear lines #3
Look here.
Do you have a loader? Did you purchase the 3016 new? If so, look at the loader manual, it shows exactly how to connect. This is very easy, I would definitely look for a different dealer.
   / Rear lines #4
Before I worried too much about the hydraulics, which is relatively small potatoes, I'd wonder how I was going to take a bh from 'a previous tractor' and fit it on the 3016. A 3pt hitch version, very easy. A frame mounted version, VERY complicated.
   / Rear lines
I have been told by 2 different dealers that "kits" do not exist. All they know is what is on the computer in front of them. I actually was told by one that they could not purchase the undercarriage kit for the hoe. I would have to buy each and every little nut and bolt. They were pushing me to buy a new tractor that came with all the stuff.
   / Rear lines
Not complicated at all. The kit comes with a part that will bolt to the non Mahindra hoe. The undercarriage bracket bolts right up.
   / Rear lines #7
There are two issues. Your original post focused on "lines" which I interpreted to mean hydraulics. If your dealer can't figure that out they are numbnuts. On the otherhand, it is certainly possible that they cannot order a subframe for your tractor that matches your older backhoe. If that is the case you might want to investigate converting the BH to a 3pt setup. Less desirable and should not be used aggressively but it would give you BH capability.
   / Rear lines
I am asking them not for a direct mount subframe to fit my hoe, but the actual frame mounted one that is made for that tractor. Once the subframe is mounted to my tractor, I will then be able to fabricate the mount from my hoe to fit the Mahindra subframe bracket. That is the ez part.
   / Rear lines #9
If you have the welding and fabrication skills to do the BH mount then you'll be able to do the subframe easily. I haven't seen a Mahindra subframe but if it is like the Kioti subframe it isn't real complicated. The Woods 4PT is difficult though.
You might be able to get a factory subframe from a related tractor model and modify it too.
   / Rear lines
My only hold up is the hydro lines. I was asking if anyone here has had the pleasure of doing this. I tried to save some money by not getting the tractor all set up in the first place. I am not sure why there are 3 lines in the kit instead of only just 2 of them to feed the hoe.
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
New/Unused 7ft 8 Drawers and 8 Cabinets Workbench (A51573)
New/Unused 7ft 8...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
