rear lift troubleshooting question
   / rear lift troubleshooting question #1
woodwoorkertim
orlando, florida
mid 1960 ford 3400
I have a mid 1960's ford 3400 diesel---
had a hydro leak which gradual drained my fluid to the point where the lift quit working. I fixed the leak (cross shaft seals in lower case )
and refilled the fluid but the lift would not work. Then screwed a valve and hose into hydraulic pump and tried bleeding the air out- thinking there was air stopping the pump from priming. Bled it with no change.
So then I ordered an overhaul kit for the pump. rebuilt pump - getting 2000 psi at idle. so looks like pump OK now.
fluid level good.
Where should I look next? lift cylinder piston o-ring? unloader valve ? what would be the next logical place to look ?
Tim
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
CATERPILLAR 259D3 SKID STEER (A52705)
CATERPILLAR 259D3...
2019 International DuraStar 4300 24FT Box Truck (A55788)
2019 International...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
BOAT MOTOR TRAILER (A53424)
BOAT MOTOR TRAILER...
2005 Ford F-750 Truck (A55788)
2005 Ford F-750...
