Rear hydrolics kit
   / Rear hydrolics kit #1
Tim V
New holland 1725
Can anyone help me find a rear hydrolic remote kit for NH 1725?
   / Rear hydrolics kit #2
Are you able to turn wrenches and do the work to put it together yourself? IF not, I would just talk to a New Holland dealer (more costly but easiest way to get it done.)
What do you need the remote to do? Raise and lower (double acting cylinders?) or continuous power (backhoe / log splitter?) or run a motor? Also, how many remotes do you need?
Your tractor is "Open Center" but I do not know if New Holland uses "Power Beyond" or is just open center. Do you have a front end loader on your tractor?
If not, it's not impossible to add remotes - just a whole lot more work!
If yes for the loader, that valve/spool will have 2 lines for the lift, 2 lines for the curl, how many extra lines are there? Is it just 2 more lines (Power In and Return to the tank) or is it 3 more lines (Power In, low pressure return to tank and Power Beyond)?
Welcome to the site... the more information you can tell us the more we can (try) and help you. (I don't know much about New Holland but hopefully someone else will chime in here....)
   / Rear hydrolics kit #3
You might search this number for openers. 718347013 kit. If you can find one it should be around $1200 or so by the time you get it home. If that suits you, great. If not, there are some less expensive options. Your choice.
Thanks for the part #!
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
KJ 11'x19' Single Steel Carport (A50121)
KJ 11'x19' Single...
Chevy Car (RUNS)(TITLE) (A50774)
Chevy Car...
2018 Nissan Titan Crew Cab Pickup Truck (A50323)
2018 Nissan Titan...
3.5 x 8 Hydraulic Cylinder (A50515)
3.5 x 8 Hydraulic...
2015 Chevrolet Duramax (A50120)
2015 Chevrolet...
