Rear hydraulics on Case 444
   / Rear hydraulics on Case 444 #1
mkow1234
Detroit, Michigan
Case 444, 446
Hello Everybody. I inherited a Case 444 garden tractor, which has front and rear hydraulics. The front has a push blade that goes up and down just fine (activated by lever on right side of engine cowling). There is also a lever on the RIGHT side of the engine cowling, to raise/lower the rear hitch for attachments. When I attempt to move this lever, nothing happens. Seems like the lever has some resistance to it (So I'm not forcing it). What am I missing? Seems like front and back must run off of the same system. Is there a switch or valve I need to activate? I should mention that currently, I do not have anything attached at the rear of the tractor, but the hitch should move up and down. Also, what size bolts do I need for the four holes on the receiver hitch to attach things? Thanks.
2018 CATERPILLAR 259D SKID STEER (A52705)
2018 CATERPILLAR...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
(2) DOUBLE AXLE FENDERS (A54756)
(2) DOUBLE AXLE...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
