Rear Hydraulics (3130)
/ Rear Hydraulics (3130) #1
marty236
I am going to be taking delivery of a HYD3130 and was wandering if anyone has put there own rear hydraulics on. Do you just run it in series with the FEL hydraulics. If anyone has any info please let me know. Thanks.
/ Rear Hydraulics (3130) #2
There are plenty of posts regarding adding external aux valves for rear remotes. Assuming you don't want to use the expensive Kubota factory remotes, your best buy is to get a multi-spool Prince SV valve from Surplus Center and plumb it in series with the loader valve. The Prince SV will need to be configured for power beyond. You will have to fab your own mounting plate.
I have posted the instructions for plumbing this configuration in series with the loader valve at least several dozen times. Do a little searching for Rear Remotes and you will probably find the instructions.
KMC 3pt 6 Row Peanut Reshaker (A64127)
KMC 3pt 6 Row...
3096 (A63117)
3096 (A63117)
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
2012 FORD SERVICE TRUCK (INOPERABLE) (A65643)
2012 FORD SERVICE...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2020 FORD F-350 (A65643)
2020 FORD F-350...
