Rear Hydraulics 2013 JD 3032E
   / Rear Hydraulics 2013 JD 3032E #1
fredericton
fredericton new brunswick
2013 john deere 3032E
I am considering adding rear hydraulics for snow Blower chute control as well as other attachments , part number BLV10461, dealer tells me 3-4 hr install plus since I'm about an hour away an additional $50 service call plus 2 hrs travel at 80 per hr, so could be a $500 install cost . Just wondering looking at the set up does not seem too difficult to install . some parts need to be removed for access . Anybody done the install themselves and in so any tricks or things to watch out for , is there instruction manual with unit , anything special to do with hydraulics ie bleed lines ?
   / Rear Hydraulics 2013 JD 3032E #2
Welcome to the forum! :welcome:
I'm going to move your thread on over to the John Deere section to see if someone over there can answer your question.
   / Rear Hydraulics 2013 JD 3032E #3
fredericton
If it is at all like the kit for my rear hyd. (3rd SCV) on my 4300, it was a matter of removing right rear wheel, fender, some fittings changed out. Pretty straight forward and good directions came with the kit. I would expect your kit and task would be very much the same. Don't be in a hurry, keep everything cleaned up good before opening up hyd. couplings, and you should have no major problems.
I added the hyd. top arm link and it was one of the best upgrades for use with the iMatch quick hitch and its many attachments.
:welcome: to TBN
Electric Mobility Scooter (A51694)
Electric Mobility...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
1268 (A50490)
1268 (A50490)
1977 CATERPILLAR D6D (A52472)
1977 CATERPILLAR...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
