Rear Differential Lock-up
   / Rear Differential Lock-up #1
phyxer
Batesville, AR
Kubota B2620
I have a question concerning the lock-up and unlocking of the rear differential on my Kubota B2620. When I push down on the pedal behind my left foot which is supposed to lock-up the rear differential, sometimes it is very easy to push and it immediately locks up the rear and sometimes it is harder to push and seems to be hit and miss as to whether it locks up the rearend or not. I have tried this while in motion (slow speed and neither wheel spinning) as well as while sitting still. ALSO, as for getting the rear end to unlock once it's locked up can be hit and miss as well. Sometimes it will unlock immediately when the pedal is released and sometimes it takes several seconds and or a few cycles of the pedal for it to release. I look forward to your opinions on my experience as well as your experiences with your rear diff lock up performance. Thank you in advance. :p
Troy
   / Rear Differential Lock-up #2
The above described is normal operation.
Unless the gears are precisely aligned, it will not lock. It is hit or miss.
Try clicking your heels together 3x first, that works on mine. :rolleyes:
   / Rear Differential Lock-up #3
ditto normal operation. On my tractor, the diff will release when I least expect it and the pedal will pop loudly and scare the crap out of me. :eek:
:D
Well I guess the good news is that there is nothing wrong with my tractor. The bad news (if there is any) is that the lockable rear differential system is not a precision based system and this leaves a little to be desired. Oh well, I doubt I'll ever truly need it but if I do I'll know to be patient and talk nice to it and it will kick in and out when it gets "around" to it! Thank you very much folks! :p
Troy
   / Rear Differential Lock-up #5
I've only used the DL a few times since we got it in '93...and not once since I put chains on the front. Seems to me the book advises to drive straight while using that. You probably already knew that but for those that don't...it's important to know.
Thanks for the reminder savage. Yes I do know this but turning is how you can tell if it unlocked or locked. I only turn in gravel or grass or garden, never on a solid surface. Thanks again for the reminder. :p
Troy
   / Rear Differential Lock-up #7
First of all, yes that is normal.
But it won't take long for you to figure out exactly how to get it engaged and disengaged right when you want it to. I use the diff lock a lot on my hilly terrain, and after it breaks in a bit, it engages and disengages much easier. Couple that with the operator brain-heel break-in period, and it becomes a fairly flawless system. :cool:
I think the only reason it is recommended it be engaged only when going straight is that both rears lock up and spin together, so even if you do try turning the fronts, you'll still go fairly straight ahead. :D
   / Rear Differential Lock-up #9
Theres no place like home.
:D;)
Last weekend I got my front axle burried and started to auger-in with one of the rears. I clicked my right heel on the diff lock pedal, closed my eyes and prayed:
There's no traction I'm lackin'.
It would be nice to say that she pulled right out of the slop, but I had to do the FEL shuffle.
-Jim
   / Rear Differential Lock-up #10
I use the push down on it easy while applying forward then backward motion to engage it when I get on uneven ground and start spinning tires. I know, it doesn't seem possible that you could lose 4wd traction with the BX. But sooner or later it'll happen.
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
*Selling at Royal Auction Zephyrhills, FL Location* (A59230)
*Selling at Royal...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Insulation (A56860)
Insulation (A56860)
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2018 INTERNATIONAL...
Tractor (A59228)
Tractor (A59228)
