Rear crank seal leak in YM1700
   / Rear crank seal leak in YM1700 #1
BTackett
Knoxville, Tn
Well I was under my tractor last night that I just got a week ago and looking at location of everything and notice oil starting to drip of the bottom of the bellhousing. I removed the npt water drain plug and about an ounce of oil ran out! I assume this is a rear seal leak basically the same as in a auto engine. Arrgh.... I did not see a leak when I bought it but the chassis had been cleaned. I have put 3 hrs on it since bringing it home and now this. I am going to call the seller today and see what they say. They gave me a 6 mo warranty and I feel this should cover this but I am almost 4 hrs away from them.
Basically, is is the same type seal in a auto engine ? Will the tractor have to be split to repair? I would assume so as the clutch is probably damp with oil now and needs to be cleaned and / or replaced.
Everything works perfectly on the tractor and now one of the worst oil leaks you can have. Just frustrated:(
Bill
   / Rear crank seal leak in YM1700 #3
If it does turn out to be the oil seal I would tell the dealer that he should give you another tractor considering you have only put 3 hours on it. I am sorry to hear about that. I don't see any way to replace it without splitting the tractor.
I called them and they are nice reputable guys and are going to fix it. I just have to haul it 7 hrs round trip and wait about 3 hrs for them to split/fix it. Everything else on the tractor works great and I would like to keep this one as I know the condition now after using it. He even said that he would help me on fuel cost to bring it to him. I was just wondering if it was the same process as a regular auto engine after splitting. I understand about the age of the tractor but just kinda disappointed that it is the rear main leaking and not a head gasket or something I can fix in a couple hours by myself.
My dad is retired and I can probably talk him into taking it for me in return for a favor.
Bill
   / Rear crank seal leak in YM1700 #5
I am glad that they are going to take care of it. I did rebuild the engine on my YM1700 earlier this year but, I did not split the tractor or pull the crankshaft as the main bearings seemed fine. Looong story but, I ran mine hot and had to rebuild it. I looked at Hoye's website and found the seal. (an $11.80 part). it does not look like it would be too bad to replace except for splitting the tractor. You can see the breakdown here:
CRANK_SHAFT: Yanmar Tractor Parts
Good luck with your tractor. I have really enjoyed using mine except for the rebuild part. It is amazing what a 20HP tractor can do.
I must say the guys at Tullahoma tractor are great to work with and I would recommend them to anyone. As you know I bought a YM1700 a couple of weeks ago and the rear seal and axle seal were dripping. I loaded the tractor this morning and headed on a 3 1/2 hr drive and in a little over 2 hrs they split the tractor, replaced the badly leaking rear main seal, put in a new clutch pak w/ bearing(while it was apart), replaced the right rear axle seal/hub, and also changed the fan belt( had to drain radiator) and gave me a PTO shield/bolts to install and I am back in business. When I got back home I put another 45 min on the tractor cultivating the garden and no leaks!
I would recommend these hard working guys to anyone for Yanmar sales/service. I don't know anyone else that would do that for you on a used tractor. I know from reading on here there are a few that will do the same but I have not used them.
Great guys! Just thought I would toot their horn.
I only paid $2500 for the YM1700 with 660 hours and original paint.
Bill
   / Rear crank seal leak in YM1700 #7
Looks like you indeed picked a good dealer to buy from....Now go work that tractor
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2011 TROXELL COMPANY 130BBL VACUUM TRAILER (A53843)
2011 TROXELL...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
Light Tower (A52377)
