I have a JD 4320 that is 47hp with r4 loaded tires and 4x4 with the ehydro transmission. with the loader I believe it weighs around 5700 lbs. I would like to add a 6 way hydraulic rear blade but don't know what size to get and what would be to big. My FIL has a 8' I believe modern ag but it is cat 2 and my tractor is only cat 1 so there is not a good way to test. the primary function of this will be to clean out ditches. most of the time it will be spent swung out to the side and angled down. the soil type will vary between sand and some clay. all of the gravel is red clay gravel. I do have a land plane for smoothing the top of the road. were lucky if we get 2" of snow a year so that is not a use for it.
anyone have any ideas of what I should be looking for. I don't want a blade that will bend the first time it hangs a root and also don't want a 10' blade that will stall the tractor if i set it down on the ground.
