rear blade repair
   / rear blade repair #1
Sideways
Southern Maryland
I just picked up an older rear scraper blade that is bent in a few places and needs some TLC.
The price of the blade (free) was to good to pass up.
Right now the blade currently swivels 360 degrees so I can push or pull with it but since I need to dismantle the blade from the 3 pt hitch to repair the bends what do I need to do to make the blade tilt as well?
   / rear blade repair #2
You could add gauge wheels and then use them to adjust for pitch. There are a zillon posts on them in the Build it yourself section.
I have a slider that has a bit of pitch adjustment, but I don't care for it very much. Adding a pitch adjustment to the blade itself without using gauge wheels would depend on how your blade mounts up to its carrier.
   / rear blade repair #4
No you don't have to add tilt to blade you can do this with the adjustment on draw bars of tractor.
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2018 Komatsu WA380-8 Articulated Wheel Loader (A51691)
2018 Komatsu...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
44in Tooth Excavator Bucket (A51691)
44in Tooth...
2014 PETERBILT 579 SLEEPER (A52576)
2014 PETERBILT 579...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
