Rear Blade Rear blade info.
   / Rear blade info. #1
Thomas
Epic Contributor
Lebanon,NH.
Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
Do you folks know of a company that offers manuel sliding both ways rear scraper blade? /forums/images/graemlins/ooo.gif about 5 foot in lenght. /forums/images/graemlins/smile.gif
   / Rear blade info. #2
Thomas,
I bought one a couple of months ago. I think the brand is "International" (not IH). I can slide it left or right and it is a 5-foot blade. I can take a pic of it tonight if you like. I think I paid about $225 for it.
-Frank
   / Rear blade info.
/forums/images/graemlins/smile.gif..that would be great.
How does it work well when off set winging back snow banks when traveling?
Well off to find the website. /forums/images/graemlins/cool.gif
41F..Blue sky w/light wind. /forums/images/graemlins/smile.gif
   / Rear blade info.
BINGO..and thanks for your effort. /forums/images/graemlins/cool.gif
41.3F..Blue sky w/light wind. /forums/images/graemlins/smile.gif
   / Rear blade info.
Re: Rear blade info. *DELETED* *DELETED*
Post deleted by Bird (I thought I'd just delete it completely since it was an exact duplicate, but apparently I did something wrong and that didn't work.) /forums/images/graemlins/frown.gif
   / Rear blade info. #7
Midwest is the OEM for Kioti. If you have trouble finding a dealer that carries Midwest, try a Kioti dealer.
I like the design of the Midwest because it takes no tools and no re-leveling of the blade to offset it. A couple pins and slide it to the right or left.
Don
   / Rear blade info. #8
Thomas,
I just got the 7' model of this 5 ft slider you can call McGrew Equipment directly. I paid about 180 for my blade.
Larry
   / Rear blade info. #9
I believe Midwest also makes the rear blades for Corrhier Equipment, who is a sponsor and advertiser on TractorByNet.com.
I picked up their 5' model that also has the tilt feature and it is a great blade. The think I like the most is that you can make all the adjustments to the blade without tools, the Offset, Angle and Tilt settings are all adjustable with PINS instead of bolts, like on some other brands. Even with gloves on, you can adjust their blades.
I did find that if I am going to doing adjustments to the OFFSET feature in the field, I will spray a light oil lubricant onto the channel that the blade pins into to make it easier to slide the blade from side to side when making the adjustments.
   / Rear blade info. #10
I forgot to mention that Corriher sells the blades in various colors so if you are concerned about matching your implement to your tractor they can probably help you out.
2016 Ford Fusion (A50515)
2016 Ford Fusion...
John Deere 24" Backhoe Bucket (LOCAL TOWNSHIP) (A50774)
John Deere 24"...
Bale Ring (A50515)
Bale Ring (A50515)
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
8' Agritek 3Pt Grader (A50515)
8' Agritek 3Pt...
