liledoun
I added an angle cylinder to my standard blade. The cylinder was one that Princedirect had as surplus for $20.00 and I just added some brackets to the blade for the cylinder. I connected to the third control valve on my JD 4300. That along with the top and tilt gives me full hydraulic control over the blade angle, tilt .
It is a little hard to learn to use on uneven ground but works great. The vertical position of the blade can be controlled within a small range with the TNT but the rock shaft does the main lifting and vertical adjustment.
The cylinder is easily removable by just pulling out the end pins. This lets the blade be used revered or manually adusted with the stock angle pin.
I have more pictures at this Link
Jim
Jim
