Rear Blade for B Series
   / Rear Blade for B Series #1
davatk
Flint Hill, Virginia
Kubota B2630
More advice needed,
Hi all,
Would like some advice on rear scraper blades. I will be wanting to purchase one between now and next fall for my B2630. Would like recommendatons on blades, lengths (5 or 6 foot ?) and good durable models. It will be used primarily for pushing snow, maybe a little bit of grading. I'd like to get something as cheap as possible, but also something that will be durable. Not too concerned about a bunch of bells and whistles.
Of course some color that matches Kubota Orange would be preferred.
Thanks for any info !!
   / Rear Blade for B Series #2
I opted for a 5' Land Pride blade that would tilt, RBT1560. The main reason I chose the 5' was because I wanted to be able to use it to dig a trench. I tried the 6' one on my 2920 and it was difficult to raise it high enough to be able to both angle it and tilt it to the max positions for that purpose. It will cover my tracks when I am pulling it and it is angled to the max position, but only just. You will probably find the 6' size is the more popular choice for that size of B. I happened to find a Kubota dealer that was going out of business and bought the blade from him.
   / Rear Blade for B Series #3
Go for the 6' blade the B2630 should handle it with ease. I bought an old 6' King Kutter (TSC sells those) and pushed snow with it and graded my driveway. You would have to decide if you want one that tilts or not. Meaning the ends of the blade can be set at different angles ie. they move up and down like a see-saw. The tilt option is nice as you can just leave the blade to "float" and it will follow the changes in the terrain while plowing snow. Naturally it is more expensive too. Most manufacturers make light, medium and heavy duty models. I would say go for the medium. The light duty may not last and the heavy duty, well, may just be too heavy price wise.
   / Rear Blade for B Series #4
Go with a 5' blade for snow. 2 reasons off the top of my head are 1 you can pull the pin and rotate the blade 360 degrees without hitting anything on a B. You will change the position of the blade at least a few times pushing snow. 2 while your tractor has the hp needed for a 6' blade it doesn't have the weight to handle it when pushing more than a few inches of snow.
   / Rear Blade for B Series #5
You can rotate the 6' blade on any of the B tractors 360 degrees I have done that on both B7510 and B7800. Yes the weight is a bit on the shy side but I have managed to plow 20" deep snow with the B7510 (1800 lbs) and it still worked. The 5' blade when angled would barely (if at all) cover the tire tracks of his B2630. If it is used for grading it would be a bit of a pain.
   / Rear Blade for B Series #6
I agree 100% with easygo
   / Rear Blade for B Series #7
I would recommend getting the Landpride RBT1572. I have an RB1572. Wish I would have got the tilting model. I bought the 60" model with my B3030. I soon traded it back to the dealer for the 72" model. The 60" model is not wide enough when it is angled. The B2630 and B3030 will lift it high enough to do what you need it to do. It will not hit anything when you want to reverse it, either.
   / Rear Blade for B Series #8
We have a 6' Landpride that goes on our B7510 at times, the B is really a little light to be pulling it (chains or R1s instead of unloaded R4s and front weights or more weight in the bucket would probably very helpful), but it does ok clearing loose snow.
Edit: I think ours is the RBT1572 as it lets you set the side to side angle with a pin. I pull the pin for snowplowing as the blade follows the ground better that way.
Aaron Z
   / Rear Blade for B Series #9
In the spirit of being cheap I bought a 5' KK yellow blade from TSC. $300 and worked great. I thought an offset of a foot or so would have been nice and so would tilt but for the big blizzards we had it was great.
   / Rear Blade for B Series #10
I had a 5' King Cutter for a 7610 and bent it all up. Caught some roots on a corner and that was the end of that. I am getting ready to get a Land Pride 60" RBT15, spend the money now or do like I did and pay twice. I personally would don't ever buy a light duty blade again unless all I ever wanted to do was move snow..
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
Toyota 7FDKU40 7,350lb Forklift (A55973)
Toyota 7FDKU40...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2018 International (A56858)
2018 International...
