Tires Rear axle wheel hub
   / Rear axle wheel hub #1
cjdiehl
Hi, I have a Kubota B7100D, the model of which was the first 4-wheel garden tractor built. The old hubs were wore out so I purchased new. The new ones are of a much improved design, but If I install them with the furnised hardware, the stud threads are recessed in the nut (2) threads, it certainly does not look correct. The old hubs had a set screw to tighten the "hex on the axle and were steel. The new ones are brass with a wedge type assembly for the axel lock. Not sure if the flatwasher is a spacer to prevent the hub from cracking or a normal installation of flat, lock, and nut.
Regardless, the studs are only long enough to attach the lug nut as was on the original hub. Help!
Thanks, cjdiehl
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2018 John Deere 331G Compact Track Loader Skid Steer (A50322)
2018 John Deere...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
VERMEER 605F ROUND HAY BALER (A51243)
VERMEER 605F ROUND...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
