Rear Axle Seal Replacment Massey Ferguson 35X
   / Rear Axle Seal Replacment Massey Ferguson 35X #1
sonichead
Ireland
Massey FE35X
Hi Guys,
Just looking for some advice on replacing a rear axle seal on a Massey Ferguson 35X, Oil would appear to be leaking into the brake drum on the rear LHS. Very noticeable now with oil on the tyre when tractor has been idle for a few days and breaks totally gone on that side. If anybody out there has tackled this job in the past what advice could you give me, apparently just replacing the inner seal can in some case be adequate to fix the problem. This is my line of attack if it fails then I'll have to replace both seals. There is some mention of shims and checking axle end float which worries me a little. Can I just remove the wheel and hub draw the axle; replace seal and put all back as I found. Thanks in advance for all your help and advice it is very much appreciated looking forward to hearing from you guys.
Thanks B
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2015 FORD F-250 SUPER DUTY (A52472)
2015 FORD F-250...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
Cattle Feeder (A50121)
CAT Skid Steer Grapple (A51573)
CAT Skid Steer...
