Rear Axle Oil Change Ford 445 A
   / Rear Axle Oil Change Ford 445 A #1
ktovar
Lake Elsinore Ca
Ford 445 A
I had a major screw up and accidently drained my rear axle oil by pulling the PTO shaft out not realizing all the oil would come pouring out!!! Oh boy did it ever.
I found the oil fill plug at the top of the rear axle behind the seet. Can anyone tell me how to check the oil level as I am adding oil to the rear axle? Is there a weep plug that I need to remove someware?? Please help, I don't want to over fill the axle.
Kevin
   / Rear Axle Oil Change Ford 445 A #3
Level plug is a 1/4" pipe plug with either a male square head or female hex (allen) head. Located on the RH side of the rear axle housing ahead of the RH trumpet housing and above the difflock pedal .
   / Rear Axle Oil Change Ford 445 A #4
Hey Kevin, the transmission and rear end are combined there is a plug on the right side of the trans most likely a square headplug. This is the fill level and it requires THF. (. Tractor hydraulic fluid) i got the info from my local Massey Ferguson dealer. I have a question, have you had any problems with an axle locking up? Thanks, Kevin M TaterK
   / Rear Axle Oil Change Ford 445 A #5
Your Massey dealer should stick to a brand he knows about.
Transmission and rear axle are not 'combined' on any 3 cylinder Ford tractors. I think I just figured out why your RH planetary gearset is toast.
   / Rear Axle Oil Change Ford 445 A #6
What type of oil should be used? Also, where does the transmission and rear end separate?
   / Rear Axle Oil Change Ford 445 A #7
Use New Holland 134 hydraulic oil or the equivalent. They separate exactly where the two castings are bolted together.
   / Rear Axle Oil Change Ford 445 A #8
Thank You!
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55218)
2015 RAM 5500...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
1263 (A50490)
1263 (A50490)
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
