Rear Axle Noise
   / Rear Axle Noise #1
Don Saltzman
Colorado
My L 3710 with many, many hours, has recently developed a "thump" in the left rear wheel axle area. This sound is heard as the wheel rotates, forward or backward, in gear or in neutral just rolling along. Sometimes it sounds like a "thump" and sometimes it sounds like a "bang". It occurs only in the left rear axle area. What can it be?
   / Rear Axle Noise #2
Did you check your wheel bolts. May be a loose wheel.
   / Rear Axle Noise #3
If it isn't loose wheel bolts, it may help isolate it to lift that side with a floor jack and just turn the wheel with the trans in neutral (engine off). See if you can get the noise to repeat itself. If it is a broken roller in the bearing, there may be a rough spot you can feel as the wheel turns.
The description of it sometimes sounding like a bang is a tip-off to a possible failure of a "hard part" - like a broken bearing roller or gear tooth in the final drive. /forums/images/graemlins/frown.gif
Hope it is simpler than this - good luck. Dick Bargeron
   / Rear Axle Noise #4
Hello,
Have you checked to see if the hub is loose on the shaft. My kubota a B6200 did the same thing about 8 years ago. Mine has a adjusting bolt to take up the slop as the hub wears from torque from the shaft. Yours may be the same. Good Luck!
SAND BLASTING CABINET (A53843)
SAND BLASTING...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
