Rear 3PT "Hoop"
   / Rear 3PT "Hoop" #1
jebb
Central Kentucky
Kioti DK35
When I first start my Kioti DK35 my 3 pt attachment gets a "hoop" while in the elevated position. After running the tractor awhile it goes away. I have tried running the 3 pt up and down a number of time, however that doesn't stop it. Any ideas?
   / Rear 3PT "Hoop" #2
I am not quite clear what you mean by "hoop"?:confused:
   / Rear 3PT "Hoop" #3
Clearly being elevated means you can get a hoop a lot lot easier (such as a slam dunk) than from flat on your back.
Seriously though, I'd like to know what you mean by that also. Is the 3pt wavering up and down?
   / Rear 3PT "Hoop" #4
I would guess he is referring to a hydraulic pulse seen at idle. it probably goes away when the engine speed is increased. it's caused by poor hydro flow...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
HEAVY DUTY QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
HEAVY DUTY QUICK...
TEST BID LOT (A50774)
BANDIT 2550 50HP WHEELED WALK BEHIND STUMP GRINDER (A51242)
BANDIT 2550 50HP...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
