Rear 3 point Hdraulics
   / Rear 3 point Hdraulics #1
fayjim2
New Holland T-1510
I would like to know is there a easy way to run hydraulic lines to rear area to run a splitter? I have a New Holland T-1510 The dealer where purchased said 800$ that sounds crazy for some hoses and fittings or am I really missing the big picture? I just need something that will work for couple days per year. Thanks Jim
   / Rear 3 point Hdraulics #2
The $800 kit probably includes valves and lever linkage that's designed to fit on your tractor. For example the rear remote kit for my Branson has valves that bolt to the rear transmission housing where the hydraulic feed to the 3pt bolts on and a set of levers that mount to the floor of the operator station next to the seat. Between them there's a set of levers and pivots to make a linkage.
You can install your own valve on the fender or bolted to a bracket on the ROPS. The hoses are fairly simple once you understand the concepts and can map them to your tractors plumbing.
The other option, since your splitter has its own valve, would be to install a backhoe loop with quick connects. This lets you break the chain that goes from valve to valve and insert additional valves (a backhoe has a whole stack of valves). Normally it would go between the loader and the 3pt. That's a matter of figuring out which is the loader valve's power beyond port (it's usually connected to a hose that goes to the back of the transmission area), and adding quick connects to it (and probably some new hose as well). The splitter's valve is probably rater for more GPM than the tractor flows but you'd want to check to be sure.
With the loop you'd stop the tractor, disconnect the loop and plug the splitter into it. Then do the reverse when you take the splitter off. You have to keep the loop connected otherwise the pump deadheads and the 3pt won't work.
   / Rear 3 point Hdraulics #3
Do you have a loader? If so you can tap into the loader PB and T lines to add an extra valve.
If you don稚 have a loader, you should have a manifold near the pump that allows to to install hydraulics for the loader valve. You can tap into the manifold to supply oil for your rear hydraulics.
   / Rear 3 point Hdraulics #4
Do you have a separate pump for the power steering?
Important because if you do NOT, then there is very little hydraulic flow to do much besides raise the 3 pt.
Type: open center
Pump flow: 6.2 gpm
Steering flow: 3.8 gpm
The above is from tractordata.com.
If the one pump provides flow to the power steering, it will do so through a priority flow control valve which will, regardless of the steering needs, reserve 3.8 gpm of the pump output which is not available for any other use leaving you with 2.4 gpm of flow for your splitter.
Generally, it is not wise to put hrs on a tractor for a job a cheap Chinese engine can do.
A splitter with a special pump which has high flow-low pressure which switches to low flow-high pressure will do your work in a fraction of the time your tractor powered spiltter will accomplish.
Dave M7040
UNUSED AGT 32-743 60" HYD GRAPPLE (A51248)
UNUSED AGT 32-743...
2009 Chevrolet Trail Blazer SUV (A51694)
2009 Chevrolet...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
2024 PETERBILT 389 TANDEM AXLE SLEEPER (A53426)
2024 PETERBILT 389...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
