Really pleased this a.m.
   / Really pleased this a.m. #1
GrayBeard
Pa.
It was 0 degrees this morning.
I wanted to move my tractor out of the shop to complete the fabrication of my snow plow mount.
The shop is not heated and I figured this might be a "battle" to get her started but lo and behold it started right up.
'Just cycled the glow plugs 3 times and hit the starter and away she went, no block heater or anything.
I am planning to get a heater but I haven't yet.
There's two kinds of luck; 'guess I had the good kind today.
GrayBeard
   / Really pleased this a.m. #2
I went out this morning just to start my TC18. Had been since late November I guess since it's been run. Battery a little weak, but after 2 attempts with the glow plugs, started up. I was pleased too!!! Also found a hydraulic leak while it warmed up, so that's all fixed now too /forums/images/graemlins/grin.gif
   / Really pleased this a.m. #3
Gary
I have had a diesel tractor for many years. When the battery was new it would start without any problems.
I installed a block heater on my <font color="orange"> Kubota </font> B 2910 this fall. Yesterday morning it was -5 Fahrenheit out. Plugged the heater in for about a hour. Tractor started up easier than it does at 40 degrees with no heater. /forums/images/graemlins/cool.gif
I don't know why I waited so long to install a heater. /forums/images/graemlins/tongue.gif
It only took a few minutes and cost was less than $50. /forums/images/graemlins/smile.gif
   / Really pleased this a.m. #6
My TC29D came with a block heater, but have not untied it yet to use it. I probable should for the days that I do leave it sit outside. Typcially when it sits outside and then I use it, it will end up in a heated space.
murph
   / Really pleased this a.m. #7
On Saturday I went out to see if my lttle tractor would start. It was about 12 degrees. She popped right off. Smoked and knocked a little. Once warm I took it for a ride out in the field. My wife caught me....she said I was nuts to be outside in the cold on a tractor just to ride it. I just smiled back. I thought it was a great time!
   / Really pleased this a.m. #8
I know what you mean, these new machines are easy to start. I popped mine off the other morning at -22 with two cycles on the glow plugs, never even coughed. The hydraulics on the other hand, took quite a while to warm up to the point where it wouldn't "cry". I just took it easy and soon enough (20 minutes of running), it was working like it was 50 degrees.
Here's a question - I've yet to put any fuel additives into what has come from the pump. Our fuel is winterized around here, so I figured I was all set. Am I flirting with disaster?
Brad
   / Really pleased this a.m. #9
</font><font color="blue" class="small">( I've yet to put any fuel additives into what has come from the pump. Our fuel is winterized around here, so I figured I was all set. Am I flirting with disaster? )</font>
asked the same question a week or so back, i just use the fuel as i get it, and in 3 years i have never had a problem, of course around here it don't get much below 0 deg. on areally cold day about -5 but that is only once in awhile
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2016 Chevrolet Traverse 1LT SUV (A50324)
2016 Chevrolet...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
Set of Rubber Skidloader Tracks (A50774)
Set of Rubber...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
