AUSTENNN10
This has my attention. I have 11 pallets of block coming in 3 hours. Each pallet weighs 3,825. The tipping load straight for a Kuboda R520S is 3,870.
I am assuming that the load limit is the limit, it will tip if you go over.
I need to at least backup and lower the load. This will be done in the street. I plan on taking block off the pallet prior to lifting.
Advice-How many 85 pound blocks should I remove? What should I look for and or be aware of. Lower as slow as possible seems to make sense.
I am an LS 3033 owner but this is out of my norm.
TIA
TIA
