Real TC29 Hydraulic Flow?
   / Real TC29 Hydraulic Flow? #1
Vermonster
Fairfax, Vermont
NH TC29S
The brochure for my TC29S shows a hydraulic lift pump capacity of 6.6 GPM and a power steering pump capacity of of 3.5 GPM. Is there any cross-over between these two systems--hydraulic lift and power steering? At my rear remote, should I expect 6.6 GPM or 10.1 GPM?
   / Real TC29 Hydraulic Flow? #2
Vermonster, I'd say you'll have the 6.6 GPM or less. I say that for a couple of reasons. Since the 6.6 is the maximum for the pump, that doesn't mean you'll have that much flow everywhere. As an example, my Kubota specs call for 6.4 GPM for the 3ph and 3.1 GPM for the power steering, but the hydraulic outlet block says for a maximum of 4.5 GPM. So, I think I'm right about that; any of you hydraulic experts know otherwise?
Bird
   / Real TC29 Hydraulic Flow? #3
Bird is on the right track. There is no commonality in the power steering and main hydraulic systems. You will measure something marginally below the hydraulic pump's spec at the hitch valve, loader couplers, or remote valve couplers; and remember flow is porportional to engine RPM.
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
UNUSED MOWERKING QUICK ATTACH TRENCHER (A51244)
UNUSED MOWERKING...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2025 GIYI Dual Cylinder Hydraulic Grapple Plate Bucket Skid Steer Attachment (A50322)
2025 GIYI Dual...
2016 Ford Explorer...
