Real axle hot
   / Real axle hot #1
Anonymous Poster
Epic Contributor
Just starting using my new bx-2200. I noticed when I washed it down that steam was coming up from the rear end. The axle is hot to the touch. Is this normal ?
Last week I left the parking brake on for about 15 min while in 4 wheel drive and didn't notice it. It was hot after that also.
Had to add fluid that night.
I have the 60 mmm, fel and 5'rake.
   / Real axle hot #2
The hydraulic fluid normaly runs about 100 degrees over ambient temperature, so yes it will get hot. Nothing to worry about.
   / Real axle hot #4
Just a thought.....you might want to be careful washing your tractor while it's hot. Cold water on a hot tractor is not a good idea.
2018 Kubota RTV-X1100C 4x4 Diesel Utility Cart (A51694)
2018 Kubota...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
JOHN DEERE 850K LGP CRAWLER DOZER (A52705)
JOHN DEERE 850K...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
