Ready to cry over my TC-24D
   / Ready to cry over my TC-24D #1
SacandagaBrad
Platinum Member
Southern Adirondacks, NY
TC24D
Hi all, been a while since I've stopped by.
Had my TC-24D since October 2003, bought brand new and been a good machine. Used for grading private gravel road, clearing snow off of same and driveways, mowing about 1.5 acres, built a couple driveways, general loader work, moving docks, basic home owner stuff. No commercial use, never abused. Has 60" MMM, 72" RB, 12LA loader, and a Woods 54" rear snow blower. Over 900 hours to date, fluids changed according to schedule, but will admit the 300 hour service is over due by about 20 to 30 hours.
Just started leaking hydro fluid, coming out of the cast casing that shrouds the front drive shaft at the transmission end. Leaking enough that oil covered my mower deck after 45 minutes of mowing. Only leaked when it was running. Had a similar leak about 3 years ago that originated in the same area, oil was running down front drive shaft until it hit the bottom and dripped off. Found loose bolts at the main split in the tractor, dealer said that could stress the input shaft seal and about an 8 hour job to split and replace. I tightened the bolts with loc-tite and the problem went away. So when I described the problem this time, but with a lot more leaking, they figured about an 8 hour job.
Got the news yesterday that they split the tractor AND split the hydro tranny, machine is in 3 main pieces and several boxes. They are 11 hours into it, finding seals that need replacing but nothing severely damaged, and are now figuring 24 hours labor plus parts!!!!!!!!!!!!!
How the **** does a machine this expensive and supposedly well built have these kinds of problems? This is not basic maintenance or reasonably anticipated repairs at a certain time in its life. For the type of work I do with it, this should be a lifetime tractor. If I knew I was headed into a $2500 repair bill, I would have first considered trading it (being up front with them about the leak). Who knows how much longer it will last, they are a long time NH dealership and have good mechanics, but the bottom line is this thing is being completely rebuilt in areas that were never intended to see the light of day.
As I'm typing this, I had another thought. Back in the beginning, during the first time I ran the snow blower, I stalled it out hard. The drive shaft to the impeller fan is a straight run, no gear reductions etc. as far as I can tell. I picked up a small stone (#2 driveway stone) and pinched it with the fan. Running 2500 ish RPMs for 540 RPM at the PTO. It stopped that impeller and the tractor motor cold. Based on the scrape, the fan traveled about 10:00 o'clock to noon before it stopped. Turned out that Woods had a typo in their manual calling for a grade 8 shear bolt in the drive shaft, should have been a grade 5. I confirmed this with them. Wonder if that incident could have started all this, even though 10 years ago? http://www.tractorbynet.com/forums/attachments/31711-grade-8-shear-bolt-confirmed.html?highlight=
Anybody else ever have these problems? Up to now, I've loved my blue machine. Not so much right now, only reason I would consider another is so I wouldn't have to buy new loader and mower.
Going to talk to them this morning. Wondering if this is something I should involve the NH reps to try to get some relief?
   / Ready to cry over my TC-24D #2
I guess you can ask the reps for some relief, but your not going to get any for a leaking seal on an 11 year old machine.
   / Ready to cry over my TC-24D #3
I doubt the one rock in the blower caused the problems to develop. If it happened a lot and you were experiencing pto issues now, then that would be different.
Running with the loose main split bolts probably didn't help, but I doubt you will get much relief from NH on a ten-year-old tractor--but asking is free. Loose bolts seem to be a common theme with small NH tractors. I've found a few on my TC40.
As to the cost of repair, if it is done well, you should get many more hours of operation out of that tractor with very few issues. Bad luck, but way cheaper than a new tractor.
agreed a 10 year old tractor is beyond expecting any help from the factory. But finding I'm not alone on the same vintage and model machines as I poke around on this site, so the free questioning can't hurt. Maybe there is some help or recall on the parts etc.
   / Ready to cry over my TC-24D #5
Wow, I'm feeling better about the time I spent doing the job. Working leisurely and doing lots of reading I was about 7 - 8 hours tearing mine apart - including stopping to eat. Then putting it back together took another 20 - 24 hours - again lots of reading and looking at pictures and figuring stuff out. Also had to figure out how to "combine" the tractor back together. That took a bit. Wouldn't have been near as long had I not broken that one bolt in the case. I spent probably 8 hours on that alone.
Hmmm...24 hrs x 70 = $1680 + parts, ouch that starts getting pricey.
Yeah, no kidding! I'm now expecting $2K to $3K. Far beyond what I would consider reasonable or anticipated repair costs over the course of owning a tractor, especially within 10 or 11 years. Wondering if it is an age thing - you have nearly twice the hours I do but our machines were built the same time. Is NH capable of making seals that last more than 10 years? Or are we going through this again in 10 years? I was considering asking about a trade, where the dealer really doesn't have much tied up other than the labor in mine. But I don't want another one! Just hoping this one will get me to retirement and I'll leave it with the house when I leave this miserable state.
I get that it is a complex machine and mechanical failures happen. But to have to come up with this kind of cash on what was sold to me as a "lifetime" machine only 10 years ago at $11,500 (tractor only, another $7500 tied up in implements most of which can't be used with another brand) is unacceptable IMO. It has been well maintained and no commercial use.
   / Ready to cry over my TC-24D #7
I'm not sure how loose your bolts were back then, but seals on shafts don't expect to see angular deflection and probably were damaged. Most any brand machine might act the same way... You got my full sympathy on the repair expense though - hate that! Hope it works out decent for you.
Jim
   / Ready to cry over my TC-24D #8
Agreed. ... Tell em you want to see the parts. Seals normally weep a while before they really leak. It sounds as if there are bearing problems causing damage to the seals.
larry
So here we are 3 weeks later. Was getting put back together on July 3, but they were closed for the 4th weekend so had to wait till Monday. They had split it 3 ways, past the hydro pump all the way to the tranny. On three separate occasions admitted they never actually found a bad O ring or seal. They did not mess with the factory seals on the hydro pump itself as they looked good and didn't want to disturb them. Monday was testing day, I called from work on Tues to offer my credit card so I could pick it up after hours, came in at $2K plus tax! Got through to the manager only to find out it was still leaking!!!!!!!!!!!!! And they needed to order and replace a steel hydro line that didn't need to have the machine split again, was a simple fix. Would be a few more days. That's when I started to fume a bit. Why didn't they start there rather than split the tractor 3 ways? Seemed like having a valve job done on your truck because there was a loose spark plug wire. Basically $2K into a hydro fluid change is what it amounted to, granted it was due, but I could do that for a lot less. Fast forward to tonight, new steel line has been installed!!! And still leaking!!!!!!!!!!!!!!!!!! Needs to go back into the shop for more diagnosis. At this point considering trading, but I really didn't want to spend money on a new tractor. I'm just climbing out of a hole from putting 2 kids through college (youngest will be senior in Sept). But even worse, I have no intention of putting that kind of money into a hydro leak on an 11 year old tractor. We still don't know where it will end, didn't get a running total tonight. They are a good dealer and working with me, we'll see where we go from here. They sell NH and Kioti. They don't have a Boomer 24 on the lot and I can't get a warm and fuzzy over the orange one, especially considering they don't have a mid mount mower designed yet. I really like my old TC-24D. They have a couple used TC 24 and 26 on the lot, newer than mine but with as many or more hours, and they look like they've been through a war compared to mine. No interest, I take pretty good care of my things.
Kubota GR2120 (A47384)
1990 GMC Topkick Grain Truck (A50514)
1990 GMC Topkick...
2015 CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
Club Car Electric Golf Cart (A51694)
Club Car Electric...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
