Mowing re JD x300 series mower
   / re JD x300 series mower #1
Farmergirl138
Rainbow Flat, NSW
JD 4600 series tractor and JD x300 series mower
Hi there. We bought a 2nd hand mower to complement our JD tractor.
I went to start it the other day and although the engine turns on, there is no movement in either forward or reverse.
The parking brake is off, the bypass valve lever for free wheeling is all the way in but there is still nothing.
I can move the mower by hand with the bypass valve lever both in and out.
Further suggestions would be very welcome.
   / re JD x300 series mower #2
Check an see that a drive belt has not slipped off of a pully. I have a Troy-Built zero turn mower that has thrown the belt between the engine and the pump occasionally.
Tim
   / re JD x300 series mower #3
If you can move the tractor with the bypass in either position I think you have an internal problem with the transmission.
2013 MACK GU713 (A50854)
2013 MACK GU713...
KLEEMAN MS192 MOBILE SCREEN (A51242)
KLEEMAN MS192...
1261 (A50490)
1261 (A50490)
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
