Re: Ezee On loader on MF 135 tractor
   / Re: Ezee On loader on MF 135 tractor #1
stillatit
theodosia, mo
mf 135, kubota L39TLB
Hi I am not much at navigating this site or apparently working with hydraulics. I managed to retrofit the ezee-on loader to my MF 135 tractor; it even operated the arms to raise the bucket but there was a slight leak at the diverter so I pulled it cleaned it and noticed the silicone seal had clogged the return ( I guess) port that mates with the diverter. There are no leaks anymore but there is also no fluid generated through the diverter. My diverter is a May Hill three port type and I pulled one plug from a port, positioned the handle where I saw the hole aligned with said port and no fluid; also no draft on the three point system. My repair manual states the pump would be grinding if it was at fault and it does not. I am at a loss and would appreciate any ideas. Thank you.:confused:
2011 JACK COUNTY  130 BBL VACUUM TRAILER (A48992)
2011 JACK COUNTY...
Travel Trailer (A48082)
Travel Trailer...
19.5L-24 Backhoe Tires (pair) (A49251)
19.5L-24 Backhoe...
2015 Dodge Ram 1500 Crew Cab Pickup Truck (A48081)
2015 Dodge Ram...
2014 Ford F-350 Crane Service Truck (A48081)
2014 Ford F-350...
Pallet of (11) 10 Lug Misc Wheels (A48837)
Pallet of (11) 10...
