Re Easy Clutch Fix...Adult Beverages on Me!
   / Re Easy Clutch Fix...Adult Beverages on Me! #1
Dingbat
Cedar Island NC (Outer Banks)
YM 1700
I'm bumping this to a new post because so many of you helped and I want to thank you. The brake stomping didn't do anything except make my bride mad at me for digging holes in the ground...BUT...the mower trick worked! /forums/images/graemlins/laugh.gif /forums/images/graemlins/cool.gif I hooked it up to the finish mower and engaged the PTO and voila! Absolutely fantastic! Now, to avoid a repetition, should I block the clutch down when not is use (all the time; some times; ?) Thanks to all of you. Steve
   / Re Easy Clutch Fix...Adult Beverages on Me! #2
it's debatable whether or not it would help, considering how yours stuck in the first place...
but... looking at it from the other side of the coin, it shouldn't hurt anything either /forums/images/graemlins/wink.gif
   / Re Easy Clutch Fix...Adult Beverages on Me! #3
My NH 1920 came with a wood block to block the clutch.. and I also block the clutch on my 46 2n just because I know the front seal weeps a bit and COULD make it stick.. though it never has.
glad you got it fixed.
Soundguy
   / Re Easy Clutch Fix...Adult Beverages on Me! #4
</font><font color="blue" class="small">( My NH 1920 came with a wood block to block the clutch )</font>
So did my Kubota B2710, although I never used it. Of course my tractor stayed parked inside all the time and probably never sat for more than a week without being used.
   / Re Easy Clutch Fix...Adult Beverages on Me! #5
Don't know about your tractor but my Mitsubishi and Satoh tractors have a little flip latch down by the clutch pedal just to hold the pedal down. Never used them myself because I haven't had that problem.
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
UNUSED RAYTREE RPRB72-72" POWER RAKE BUCKET (A51248)
UNUSED RAYTREE...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53472)
Michelin CARGOXBIB...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
