Rotary Cutter Razorback RZ160 slipping?
   / Razorback RZ160 slipping? #1
waterwalkin
Husser, LA
John Deere 2040
My Razorback RZ160 cuts pretty good---but it seems to slip every now and then. Noisy rattling seems to come from the shaft area.
If I stop and take my tractor out of gear, and slowly ease off the clutch, the bush hog continues cutting. Then a while later, the shaft seems to be slipping and stops cutting. There seems to be a lot of action under the protective yellow sleeve when this happens.
I watch the pto end when I release the tractor's clutch and the pto seems to like the slow clutch release. The shaft starts turning. The gear box end of the shaft (on the RZ160) seems OK with the slow clutch release.
A normal clutch release produces rattling from the shaft area---and no rotation.
Any suggestions would be appreciated.
   / Razorback RZ160 slipping? #2
Welcome to TBN ! :thumbsup:
Guessing you have a slip clutch on pto shaft, if so is it ajusted correctly ?
Pic's ?
Boone
Thanks for the reply and the Luke 6:46.
I do not have pix but can get some next weekend. I wish I knew more about the slip clutch and the suggestion bullbraker. I inherited this from my Dad and use it to bush hog now that he's gone.
It's almost as if the inner shaft was slipping inside the outer shaft---and a slow clutch prevents the slipping.
   / Razorback RZ160 slipping? #4
Never seen a razorback with a slip clutch. They only come as an option with the Squealer and larger!!!
I'd think that you have sheared the shear pin and there is enough metal hanging that it is keeping the mower turning as long as the load isn't to high!
ANYONE. Is it possible that the driveline is damaged and needs replacement? The gear box seems OK. When I "take it easy" and release the tractor clutch slowly, the driveline seems to go along---and it turns the blades via gear box. But, when challenged in high grass or if I release the clutch too quickly---the driveline seems to slip. Anyone ever experience this? Thanks.
   / Razorback RZ160 slipping? #7
Sounds like you are going to have to remove the driveline covers and inspect the driveline. If the shaft is too short not allowing enough engagement between the two shafts, I suppose it is possible for the inner shaft to become worn and slip. Are you using the cutter on the same tractor as your Dad did?
Here is a link to the operator's manual and the parts manual which will show you the driveline componants.
http://www.bushhog.com/images/stories/documents/manuals/RZ160.pdf
http://www.bushhog.com/images/stories/documents/manuals/rz160parts.pdf
Chris,
I am using the same tractor. It's a John Deere 2040. I will check the drive line and inner shaft for wear. Thank you for the links and taking the time to post.
If Dad was around, he'd know what to do. I am a very small chip off the block.
Mark
   / Razorback RZ160 slipping? #9
Mark, I know how you feel. I lost my Dad almost 2 years back. He and I worked on all kinds of stuff together for many years. He possessed a wealth of knowledge that I fall short of in a lot of areas.
I hope the manuals help you figure out your shaft problem.
Sorry you lost your dad. My dad died January 2011. The place has not been the same. :(
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
1000 Gallon Fuel Tank W/Pump (A50774)
1000 Gallon Fuel...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
2018 GMC Savana (A50120)
2018 GMC Savana...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
