Rattling noise on loader
   / Rattling noise on loader #1
davek78063
Pipe Creek, Tx
Mahindra 2538
I have a 2538 and the lynch pin that connects the loader to the frame has a bad rattle. At full throttle rattles louder than the engine. Anyone else have that and solved the problem? I guess I could tie wrap it but was looking for something more elegant.
   / Rattling noise on loader #2
I can't stand rattles either! It is likely because it sits loose in the hole but it's not supposed to be a really tight fit or it would make it hard to pull. I'd try pulling the pin and maybe putting a couple wraps of tape on it, just enough to make it not rattle.
   / Rattling noise on loader #3
Use a spring on the pin like Kubota uses on ROPS pins.
   / Rattling noise on loader #4
I had the same exact problem. Drove me crazy. But...the good news is that it proves the weight of the super structure on the loader is not on the pins, but rather the 4" mounting cylinder, that is part of the chassis.
I've tried pulling the pins and putting a heavy dose of grease on them. Works for about 10-15 minutes. Tried wedging a few tooth pics in there, and that lasted for 5 seconds. Only thing I could get to work was to take a bungy cord and connect one end to the handle and the other to the superstructure, so it moved in concert with the up and down movement of the loader.
I understand you're wanting to keep the "fix" elegant. But once you've had the tractor for a while and have added some "character" to it (scrapes, dents, etc) bungys almost seem elegant.
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2015 Z Master Professional 5000 Series 60in Zero Turn Commercial Mower (A50322)
2015 Z Master...
2020 Case CX245D SR Excavator (RIDE AND DRIVE) (A50774)
2020 Case CX245D...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
