RATS!!
   / RATS!! #1
bikerdib
Platinum Member
Texas
Kubota L4701
I went out to the weekend place in the woods with the intention to do some tractor work with the B3300 today. First chance I致e had in 5 weeks; work keeps getting in the way. There have been a couple of heavy rain showers since I had the pond dug and some of the fresh dirt eroded; so, I was going to level that back smooth and also cut a ditch to catch and divert the watershed flow into the inlet.
Had the tractor covered with a tarp while it was parked and after removing that, I saw where a rat or two had been homesteading on the tractor. Not good! I turned the key to glowplug for about 5 seconds then tried cranking it. No start after about 5 seconds. Unusual, it usually fires right up. I shut off the key and checked the PTO shifter, yes it was in neutral. Checked the seat safety switches, yes they seem to be working. Tried cranking again. It spun over good but didn稚 even try to fire and no smoke at all from the exhaust. Then I realized I wasn稚 hearing the fuel solenoid clunk into position. Pulled the fuel stop selenoid fuse; it was OK. Ran a wire directly from the battery terminals and touched the wire connections on the solenoid and she clunked like normal. I assume the rats have chewed a wire or two somewhere and power is not being sent to the solenoid. I didn稚 see anywhere under the hood where they had done any damage so I assume they did something inside the dash consol. I came home and made some jumper wires with mini spade connectors so I can hotwire the solenoid directly from the battery to get it going long enough to load it on the trailer and bring it home. It痴 pretty close to time for the first service anyway so I値l probably just take it to the dealer and let them sort it out while they do the service.
   / RATS!! #2
If a barn cat is not in the picture, the local farm store has some nice "candy bars" that taste really good to rats.
   / RATS!!
That's the plan for the future. This is out in the deep woods so a cat probably wouldn't survive more than a few days. Coyote make snacks out of domesticated cats. I'll just have to find a place to hide the candy bars so the raccoons and squirrels don稚 find it.
   / RATS!! #5
Rats/mice did over $1500 damage to my dad's truck in one weekend! I guess it occurs so often Chevy even has a specific package to handle the repair. They had to yank out the whole dash to replace the harness. Only solution around here is build mouse-proof buildings for things you want to keep. :thumbsup: They love those nice warm engines.
   / RATS!! #6
Try a cat rescue shelter and tell them you want barn cats. Keep them in your barn or garage for a week and feed them there, They may get used to you or they won't but the trick is to keep them around. Have had a few run off as Well as lose an occasional cat to predators, and I believe it is only due to the cat fearing nothing. My chesapeakes fear these cats. Have had the last two for about two years now, and they are worth their weight in gold.
   / RATS!! #7
Here in Colorado I've had issues with Marmots in the winter. Same thing, they get hungry enough to eat the wires and hoses under the hood of my old truck.
Tom
   / RATS!! #8
Many Kubotas only ENERGIZE the solenoid to KILL the engine (KEY STOP), some do have 2 circuits for run and kill. Be sure to doulbe check to see if yours is this way. The solenoids only replaced pulling the fuel lever to shut down. If it is not starting, check to see if glow plugs are getting power.
David Kb7uns
   / RATS!! #9
unfortunately been there too. rodents do not like to nest in daylight, so keep your hood open if you can under a semi translucent tarp. they also don't like mothball products....i get one of those larger types for urinals and zip tie it somewhere under the hood away from heat, etc. good luck
   / RATS!! #10
A mouse disabled my 16,000 lb Cat D3 Dozer... TWICE!
Gnawed through an oil line.
80in HD Tooth Bucket with Side Cutters (A50397)
80in HD Tooth...
2007 Ford Explorer XLT SUV (A48082)
2007 Ford Explorer...
71056 (A49346)
71056 (A49346)
2019 Allmand Light tower (A49461)
2019 Allmand Light...
LoadMaster Gooseneck Trailer (A50490)
LoadMaster...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
