Rationale for Shared Hydraulic/Transmission Oil?
   / Rationale for Shared Hydraulic/Transmission Oil? #1
airbiscuit
Super Member
NW Wisconsin
New Holland T2310 (40hp), Kubota L3010 GST, New Holland TC21DA *** Previously - Farmall H, 1941 John Deere B, Shibaura SD1500, John Deere 850, Bobcat 642, New Holland 1925
I get the logic of using that large transmission housing to also be a reservoir for hydraulic oil - it's already there, saves space, acts as a heat sink, etc. What I've wondered about though is the purity of the transmission oil. We are all fanatical about the cleanliness of hydraulic oil. I seem to remember that the oil in car transmissions contained metal shavings from the gears and syncros gnashing. Apparently we just trust the hydraulic filter to take care of any metal shavings? It must not be a big deal, because it is a common design feature. Thoughts?
   / Rationale for Shared Hydraulic/Transmission Oil? #2
Re: Rationale for Shared Hyrraulic/Transmission Oil?
Thoughts?
Well, I think you have outlined it pretty well, but remember that hydro-stat equipped machines have that extra micro-fine expensive filter before the fluid reaches the close tolerance hydro parts. (slippers and swash plate and pistons). the machine relies on those filters to keep clean.
   / Rationale for Shared Hydraulic/Transmission Oil? #3
I have become somewhat obsessed with sharing oil amoung machines or buying an attachment and getting the old oil out of it.
   / Rationale for Shared Hydraulic/Transmission Oil? #4
If it makes sleeping hard, and I have had that problem for items of the sort in the past, get some magnets...HF sells them, and attach them to the bottom of your engine and TDH sump; the more the merrier. I use them on my red tractors TDH sumps. Problem solved.
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2013 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2013 MACK GU813...
