Snow Equipment Owning/Operating Rating Two Stage Snow Blowers on hills
   / Rating Two Stage Snow Blowers on hills #1
jjohn55
Naperville,IL
Looking to get a 2 stage
I am looking for feedback convcerning blowing snow on a hilly driveway. I am concerned on havign the snow blower run away from me on the downslope or falling back on the up slope by using a smaller snow thrower last year.
   / Rating Two Stage Snow Blowers on hills #2
Are you talking about a walk behind snow thrower or a 3pt blower?
   / Rating Two Stage Snow Blowers on hills #4
I use this one for the smaller areas and it is powerful and will not run on you downhill. It has a hydrostat drive system that brakes upon releasing the movement lever.
http://powerequipment.honda.com/snowblowers/models/hs928tas
   / Rating Two Stage Snow Blowers on hills #5
You shouldn't have a problem with the snow blower stepping on your toes and running away. Or have I misunderstood the question? :drink:
Honda Snowblowers: HS928TAS Two-stage Snowblower
Thanks for the tip. I had heard that the Honda unit with track drive would slip on ice? I had a small snow thrower that would tend to go downhill faster than I could walk behind it. Now with upgrading to a lot heavier unit, I am concerned that I would not be able to hold on to it if it speeds up going downhill on a slippery surface.
I have a concern about a heavy 2-stage snow blower on hills. Going down - it could run away from me. With it being heavier than I could hold, it could run away from me. Or going uphill, it could slip back on me. I had a snow thrower that I used on this driveway for the first time since we moved in. I found that the little snow thrower was hard to hold back going downhill on slippery, icy conditions.
So I guess you are saying that the bigger / heavier snow blower would not run away downhill as it is too heavy?
   / Rating Two Stage Snow Blowers on hills #8
Another vote for the Honda 928.
GREAT unit, throws further and more accurate than my tractor. I live on a hill too, and the track drive hondas are as sure footed as a mountain goat!. They can climb up stairs to blow off decks too.
Only thing Id do different is get the wider 1132. Best blower out there by far.
No way a honda with its hydrostatic drive could run away from you.
   / Rating Two Stage Snow Blowers on hills #9
I think you will find that 2 stage walk-behind blowers will stop all movement when you let go of the handlebars, unless you buy one that is nearing "antique" age.
20305 (A51694)
20305 (A51694)
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
2008 FREIGHTLINER B2 BUS CHASSIS (A52576)
2008 FREIGHTLINER...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
TAKEUCHI TL6R SKID STEER (A51246)
TAKEUCHI TL6R SKID...
