Ratchet Straps
   / Ratchet Straps #1
shooterdon
Elite Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2020 Kawasaki Mule SX; 2021 Bad Boy 54" ZT Elite
I would like to get some good quality ratchet straps to hold down totes of wood that will weigh about 2500 pounds.
Any recommendations?
   / Ratchet Straps #2
Or something similar...
   / Ratchet Straps #3
Why straps vs chain for those loads?
I usually reserve my heavy duty straps for things my chain would mark up.
   / Ratchet Straps #4
What sort of totes weigh 2500lb? I'm guessing they're not run of the mill rubber-maids.
   / Ratchet Straps #5
A 300 gallon IBC tote filled with water would weigh about that much, I'd guess a 300 gallon tote packed tightly with wet freshly cut oak or elm could be near as much.
   / Ratchet Straps #7
Check out AW Direct / Zips. they have most everything you would need.
Not sure where you are but also Triple A sling in Grand Rapids.
   / Ratchet Straps #8
I check out what truckers like.
   / Ratchet Straps #9
I have Ancra straps. Ok but made in China..
   / Ratchet Straps
These hold just under 1/2 a cord of firewood.
John Deere M Tractor (AS IS) (A50774)
John Deere M...
2000 PETERBILT 379 TANDEM AXLE SLEEPER (A52141)
2000 PETERBILT 379...
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
2014 Toro Workman HD Utility Cart (A51691)
2014 Toro Workman...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
Unused 2025 CFG MH12RX Mini Excavator (A50322)
Unused 2025 CFG...
