Oil & Fuel Ran out of fuel!
   / Ran out of fuel! #1
mtimber
Mount Sterling, Ohio
YM 2610
After reading all the posts on this board about the process of repriming a deisel engine I swore I'd never let it happen to me. I've only had my yanmar for 3 weeks now and I've already done it - ran my tank dry! I retrieved a couple of wrenches, screwdrivers and put on a pair of rubber gloves and expected the worst. However, I was pleasantly suprised with how simple the process was on my tractor. All I needed to do was to close off the valve at my fuel filter (manual lever), use a #2 phillips to open the ball valve right beside the injectors, reopen the fuel filter valve until I saw all the air flush out and got a steady stream of fuel out of the ball valve, reclose the fuel filter valve (to stop the stream of fuel from the ball valve until I could reclose it) then reopen the fuel filter valve and I was good to go. (Except the first time I did this I jumped back on my tractor and had left the fuel filter valve closed. The tractor started right up but soon died and I had to repeat the process.) You don't even need to close the fuel filter valve but I did this for more control over the fuel stream and to create less mess.
It seems Yanmar has simplified this process for some of the later models? I have a 2610. Anyone else gone through a similar process?
And one mechanical question - is it hard on a deisel engine to run dry? (not that I plan to do it more in the future just for fun.)
   / Ran out of fuel! #2
You would hate priming an F series, if you liked doing yours. You push a button on the filter and use a pump built into the fuel line. It has a hose returning back to the tank. You don't get the pleasure of smelling that sweet diesel.
A late model Hinomot is even worse. It has a relief hose back to the tank and it will self prime with no effort at all.
   / Ran out of fuel! #3
Yup, but thanks to Mr Pepper etal, no problem:
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=yanmar&Number=175714&Search=true&Forum=yanmar&Words=2210&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=175714>See this thread</A>
   / Ran out of fuel! #4
<font color=blue>It seems Yanmar has simplified this process for some of the later models? I have a 2610. Anyone else gone through a similar process?</font color=blue>
Well, maybe the new ones are self-priming. My JD4300 has a Yanmar engine which is self-priming (so they say.. I haven't tested it yet.) /w3tcompact/icons/smile.gif
   / Ran out of fuel! #5
Ok , I fess up I did run my JD990 with a Yanmar engine dry , ,,, well it was less than a quarter tank full and slite grade , just enough to let her stall out , refueled and started her up and back to work ........got to love that self primer
Bill G.
EnvisionWare's Coin/Bill Acceptor (A50325)
EnvisionWare's...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
APPROX 21 SIDEWINDERS (A52472)
APPROX 21...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
