Loader ran out of fuel. need help to prime system
   / ran out of fuel. need help to prime system #1
rkirk
spanish fork, utah
01 bobcat
Priming fuel system on bobcat 773 any volenteers
   / ran out of fuel. need help to prime system #2
Open the bleed screw of the top of the filter bass (small brass scre with either hex head or common screw driver slot) squeeze rubber primer bulb until only fuel, no air comes out the bleed screw. Close that bleed screw the follow the fuel line up to the injcetion pump, there you will find another bleed valve (knob on fitting that comes into the pump), open that bleed valve/knob and squeeze primer bulb again and until only fuel comes out, no air. Close the bleed valve and it should start. If still won't start then you may have to crack the fuel lines loose at the injectors and crank it until fuel starts spraying out of those lines. Then tighten them back up and your good to go.
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
