I hadn't ran the tractor in about a month and at that time the fuel gauge worked. I knew when I started it today it was already pretty low, but it showed that it wasn't on E yet but it only ran a couple of minutes before it just stopped. It turns over fine, but won't start after filling it up with fresh fuel and some Heet. I also tried spraying some fuel and a little starter fluid into the breather and it does cause it to sputter more but it still won't start and puts out a little bit of white smoke.
I guess my question is, is there a primer button somewhere to help prime the lines? Or any other remedy to try before I attempt to bleed the air through the rails?
TIA
TIA
