Ramps/Pickup Loading
   / Ramps/Pickup Loading #1
bcurrier
I'm looking into buying a BX2200. Does anyone here load their compact or garden tractor onto their pickup? I haven't seen any ramps that are both long and strong enough to take the the BX. Shorter is stronger, of course, but I wouldn't risk a steep ramp. I'd like to avoid a trailer, if possible.
Bill
   / Ramps/Pickup Loading #2
Can't say strenuously enough--BUY A TRAILER.
NO matter how careful you are, or how many times you do it--all it takes is 1 time. Happened to melast summer. One ramp slipped and the other went, I flew off, my 700# Honda rider came down in slooooow motion right to me. 5 minutes later, I woke up thankful to be doing so. Note: Have done this 100+ times. .....best of conditions.
Main problem is ramp angle is too steep--haven't seen a viable design I would consider. Also, at the elevation of a pickup bed, a falling tractor can do a lot of damage. The BX is no light weight--even without the loader (1300# with the mower deck, I'd guess).
You can probably find a viable used small trailer for the BX for $400'ish. New ones here in Michigan can be had starting at $600, with steel mesh gate/ramp. Nothing great, just angle iron and plywood, car tires (2) and 2000# capacity. But will last as long as the tractor with reasonable care. Plus, you can use it as a big wagon around your property behind the BX.
Good luck!
   / Ramps/Pickup Loading #3
There is no doubt that you could have ramps built by any competent welder, if you don't find ready made ones that would handle the job, but I agree with M.Sullivan. I'd buy a trailer that could be used for other things as well, and be safer. I have a 5'x10' tilt bed that I bought used for $400 that doesn't require any ramps, and I have a 6'x16' tandem axle with heavy angle iron ramps that cost less than a thousand new (for trailer and ramps).
Bird
   / Ramps/Pickup Loading #4
I have seen at least 2 different B series tractors on the backs of pick ups around here in the past year. I, too, am in the market for a trailer for my old B7100, but will not consider hauling it on my truck. What I have been known to do with my Ford LGT 165 garden tractor is back the truck up to a bank, and drive the garden tractor straight onto the truck, effectively eliminating the ramps altogether. Obviously, this is only feasible if you know there is a loading dock or similar bank at your destination.
Chris in SW Va.
LOL - ok, I'm convinced! I really hadn't considered some of the less expensive trailers (or used, for that matter). I just didn't want to get into it for another 2-3 thousand. If I can find something safe and secure, as in solid and no-sway, for 500-800, that would be just fine. I have property several hours away from home that I have to tend periodically, so good trailering would be a must.
Bill
   / Ramps/Pickup Loading #6
Most people around here have PU bed height loading docks. With a good dock, you almost don't need ramps, and if you do use ramps, they don't have far to span or much of an angle.
I have below grade cuts in my drive, and the side slopes are almost good enough. This spring I'm going to dig one out more and put in a log retaining wall. A dock should make loading safe and easy. If I didn't have a hill to dig into, I'd just dig a hole in the ground for the rear PU wheels. Anything to lower the ramp angles.
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2013 John Deere 310SK (A47384)
2013 John Deere...
2004 Nissan Armada SUV (A50324)
2004 Nissan Armada...
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
