Hi folks. I'm looking for a lightweight (aluminum?) ramp to use as a bridge to get across a little stream on my property. The property is pretty hilly, so I need to cross at several points to get to all (actually, most of) it. So I want something I can carry or drag from place to place. I'm in the process of planning some foot bridges, but I'd rather leave them for folks, and use a temporary ramp/bridge when I need to get across on the tractor.
All I can find are these ATV ramps that are made to use one per side. That's fine with an ATV or with a tractor with the tires set to narrow, but like I said, I've got hills, so I want the wheels wide for stability. And when the back tires are wide, their enough wider than the front tires that those single-wheel ATV ramps don't work too well. So what I need is either a much wider version o those ATV ramps (so that both the front and back tires on one side can be well on the ramp at the same time) or something about four feet wide. Length needs to be at about 8 feet (seven might do), and it needs to be able to hold about 2000 lbs (B7510 + loader + loaded tires).
I might end up having something fabricated, but it's likely to be cheaper and lighter if I can buy prefab. Light is nice.
Thoughts?
Jim
Thoughts?
Jim
